Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-04-2007, 03:14 PM
halfasss101 halfasss101 is offline
420A neon with auto trans to 420A eclipse M/T swap?
Does anyone know if i can swap a 420A motor with an auto tranny in a neon to a 420A eclipse with a manual tranny? Will it bolt up? Thanks
Old 09-04-2007, 03:55 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 420A neon with auto trans to 420A eclipse M/T swap?
I dont know what the hell you are trying to say. You have an auto neon and you want to put the motor and manual tranny from an eclipse in the neon?
The neon and eclipse both use 420a motors but the neon has a different head on it. The intake is on the front of the motor were on the eclipse its on the rear. Also some neons came with SOHC. But other than that the tranny should bolt right up.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-04-2007, 03:57 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Eh I did some minor research and found out that the trannies aren't the same. The motor is but it also sits 180 of the eclipse mening exhaust rear and i/m front so the tranny sits on opposite sides as well. So in theory the block is the same , it can be done. most likely need all the mounts from the old motor in the eclipse and you should be safe for the most part minus the sensors and crap because I dont think they have the same ECU.
2004 Mazda 6i
1997 Tahoe
Old 09-04-2007, 04:31 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Aren't the Neon and the Eclipse 420a's the same just one is rotated 180* of the other, or is the tranny on the same side for both and the neon head is just ass backwards?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-04-2007, 06:02 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Yes, you can if you have lots of money, time, and another car to drive in the mean-time. If you're doing it for a cheap way out because a buddy has an neon motor he'll sell to you for cheap, then no, it takes more than just a motor-to-motor swap.
You are correct in saying that the neon ehaust is to the rear and intake to the front, but that's because the head sits 180 degrees on the block, the block itself still sits on the passenger side with the tranny on the drivers side, just like in our cars.
95 Talon TSI AWD
97 Eclipse GST
Old 09-04-2007, 10:48 PM
MazdaX's Avatar
Ahh gotcha, why is the head all ass backwards anyways...seems pointless..:/
2004 Mazda 6i
1997 Tahoe
Old 09-05-2007, 01:04 AM
Cause it's a neon....
95 Talon TSI AWD
97 Eclipse GST
Old 09-08-2007, 02:19 AM
MazdaX's Avatar
I figured it out...better exhaust flow for the 300 hp that neons always have with NOS-> stickers and autozone hubcap spinners...
But honestly seems like a shorted distance to get exhaust out while maintaining decent backpressure.
2004 Mazda 6i
1997 Tahoe
