| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
About to do the big 3...
before I do it i want to ask some questions so I am sure of what I will be doing..
1) The wires i need to upgrade are: -battery ground to chassis -battery positive to alternator positive -engine block to chassis correct? 2) My system is only going to be running a 1000 watt memphis amp, would I be good to just run 4 gauge for the big 3, or just run 0 gauge? 3) Is anybody familiar with a 1994 honda accord? if soo -where is the engine block to chassis wire? -is there a stock fuse from the alternator to battery? (i think i see a fuse box but im not sure) -whats the best way to run the wire from the alternator to the battery? |
Re: About to do the big 3...
![]() Red- The red arrow goes from the battery ground to where the red X is Green- This is a bolt on the engine, can I run a wire from the arrow to the green X, and that be the engine block to chassis? Purple- The purple arrow is the battery positive to the alternator, the wire goes into the purple X, is this a fuse box? |
you can run ground wires pretty much wherever you want.
the fuse block is that black box on the EXTREME top let o that pic. The stock alt is used or 100 amps. The big 3 are in addition to the wires you already have, not a replacement. |
OK, so im adding on not replacing, gotcha
but running a wire to the green X is ok? |
Green should be ok as long as you sand it down to bare, shiny metal.
Your Batt. positive goes to the ALT postive terminal, look on your ALT to find a rubber boot, pull it back and youll see a bolt and cable, thats where you add the cable to. Recommend 1/0 gauge if possible, if not 4ga will work. Your car might not have a stock chassis to block wire. Just find a bolt on the block and put it there.
96 EJ6. Future home of boosted B18C1.
yea, I have an old CRX and I will have to add some wires too
