Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-04-2007, 11:14 AM
johnholl johnholl is offline
93 Sohc Sl1 Idle Problems
The idle races somtimes when decelerating, or when traveling downhill.
Iv'e seen the posts mentioning cleaning the IAC., however removal of the IAC valve seems a bit move complicated than shown. First off, to remove the throttlebody, one would have to remove quite a bit of vacuum, and associated fuel lines. Am I correct? Is the IAC valve the one on the radiator side of the trottle body- kitty-corner to the trottle return spring?
Secondly, I might try replacing the temp sending unit. Is there a way to remove the electrical connector without damaging the wires. I don't want to ruin the connector attached to the sending unit.
Old 09-09-2007, 08:32 PM
holdemjunkie holdemjunkie is offline
Banned
Re: 93 Sohc Sl1 Idle Problems
The throttle body is simple to get off, Disconnect the electrical connectors at the idle air control (IAC) valve and throttle position (TP) sensor. Disconnect the vacuum harness (they are just held in by a clip)Disconnect the throttle control cable. Remove the throttle body retaining bolts. Make sure that you use a new gasket and make sure that you remove all of the old gasket.
To disconnect the electrical conector at the temp sensor all yoy do is press the side of it with 2 fingers and it should just come right off. Those sensors like to crack, there is a new style out the is made out of brass the old 1 cracks because its made out of ceramic.
Old 09-10-2007, 09:05 PM
53bruce 53bruce is offline
just had the same issue on my saturn. replacing the temperature sensor solved that issue but good! You just need to make sure you replace the correct sensor, it will have 2 wires attached to it. the sensor with just 1 wire is the sensor for the temperatur gauge. the sensor will run about $15 or so
Old 10-21-2007, 10:36 AM
alexanderbevens alexanderbevens is offline
I have a 2000 sl1 and it idels normal in park and neutral but when in drive (any gear)or in reverse it wnts to idel around 2500-3000 rpm. will changeing my temp sensor solve this problem also?
