Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-04-2007, 02:07 AM
R.talon R.talon is offline
(pulling My Hair Out)
Hi, my kid pick up a 92 talon with a 140.000 on it, everything ran great tell the main brain went out; I replaced it and some other censors. Now the car is smoking I know very little about this car could someone help point me in the right direction Thanks (PULLING MY HAIR OUT)
Old 09-04-2007, 02:33 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: (pulling My Hair Out)
What color smoke is it?
We need to know more about the car, is it turbo?
I would do a compression test and see how that turns out then narrow it down from there.
Could be as easy as a headgasket or turbo, or it may be the rings.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-04-2007, 11:18 AM
This is a 92 talon non tubro, the smoke is blueish in color, I need to ad this car did not smoke at all before the brain went out. it is a auto trans
Old 09-04-2007, 12:11 PM
Holset powered 420a
Blue smoke is oil burning. Shouldn't anything to do with the ECU being replaced. I would recommend a compression test. If everything checks out there then I would look more into the head. Maybe valve stem seals.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-04-2007, 12:46 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Or rings. A leakdown test can determine which.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-04-2007, 05:50 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Where did you get the ECU? If it didn't do it before you put in a new ECU, you may have the wrong one for the car, causing it to smoke. Although I don't know why it would make blue smoke, but that's my only logical thinking right now.
95 Talon TSI AWD
97 Eclipse GST
Old 09-04-2007, 08:47 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
is it a lot of smoke, or just a little?
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
