Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 09-03-2007, 11:39 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Is changing the Timing Belt Difficult ?
I changed the timing belt in my '93 Geo Metro - very easy.
I have a '93 Geo Tracker 4 cyl. also.
Is changing the timing belt in the Tracker equally easy?
DoctorBill
Old 09-04-2007, 07:10 AM
igya igya is offline
Re: Is changing the Timing Belt Difficult ?
It's a snap! 1 1/2 hour job. I cut away a lot of plastic from top of the fan shroud with a drimmel tool, and everything just fell off into my hands. The missing plastic has zero effect on cooling. It's there to protect fingers from the fan.
Old 10-04-2007, 09:29 PM
coopdavillage's Avatar
coopdavillage coopdavillage is offline
you can remove everything very easy without cutting it away. its just a little of a tedious job just like any other replacement. one tip would be is if you have a manual transmission make sure its it gear and that will keep the gears from moving which helps a great deal (just replaced mine with the water pump and had not movement). good luck
