Go Back   Automotive Forums Car Chat > Jeep > General Discussion
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-03-2007, 11:39 PM
Sportfam Sportfam is offline
83 Jeep CJ7, Black smoke on a rebuilt carb.
Hi All,
I just replace my carted 2-brl with a rebuilt. The problem is at high speeds black smoke comes out the tail pipe. At low speeds, it runs fine and lean. In addition, I have no power to my automatic choke connection. Any ideas???
Thanks
Old 09-09-2007, 09:08 PM
rhandwor rhandwor is offline
Re: 83 Jeep CJ7, Black smoke on a rebuilt carb.
I would check that the choke opens when hot. The electric wire probably heats up the spring so the choke will open.
Old 02-03-2008, 08:22 PM
mekaniclyinclined mekaniclyinclined is offline
I would eliminate the electric choke and put a cable on its place its more dependable. the choke is probably staying partially closed at full throttle and your dumping fuel but not getting enough air. Also check that the rebuilt carb is jetted for the application otherwise it will never run right.
Old 02-03-2008, 10:11 PM
G.A.S. G.A.S. is offline
that is your choke.
I would follow the aftermarket cable replacement or installation.
Old 02-03-2008, 10:42 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Please refer to the Community Guidelines for further info about posting in old, outdated threads before posting again. If the thread has not seen any new posts in the last 3 months then do not post in it.
Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
