Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-03-2007, 10:38 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
CEL for emissions
my CEL just came back on, after about 500 miles, i know that is where the computer begins to gather positive data from the emissions system, however, i do not have a cat, so i made myself a rear o2 bypass/simulator using the DIY instructions on tuners... well, obviously, that didn't work... and i need a state inspection (OBDII)... any ideas? (i dont want to buy a cat) heard of this little trick of using "spark plug non fouler" and thread the o2 sencor into that...
http://www.scoobymods.com/forums/showthread.php?t=5468
any info from anyone will help dearly!
Old 09-03-2007, 11:00 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: CEL for emissions
What code do you have? I have no cat either and have never came up with an emissions CEL. I've heard of the resistor from radio shack you can use to bypass it, but never tried it myself (No emissions here).
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 09-05-2007, 12:09 PM
Black99GST's Avatar
P0136... something about the first bank 2nd sencor o2... dont really know what to do about that...
Old 09-05-2007, 02:43 PM
Hmmm I take it that DIY from tuners was the resistor mod? That sparkplug non fouler might be worth looking into. It looks pretty cheap, so if it doesn't fix the problem, you aren't out a whole lot of cash.
I've heard of that foil trick, putting it around the o2 sensor. But I'm not really sure how that would work out.
You said after 500 miles the CEL came back on. Any chance you could clear the codes right before taking it to get the emissions test done on it?
94 Talon 1.8L-SOLD
Old 09-05-2007, 02:59 PM
steviek's Avatar
steviek steviek is offline
yea i say you just clear it on the way to the shop
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 09-05-2007, 03:07 PM
steviek's Avatar
wait a minute if you have no cat you're going to fail emmisions anyways?aren't you?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 09-05-2007, 03:57 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
If you have to do a sniffer. I know some states don't do a sniffer but do require a visual inspection. (you can also always swap out your non cat pipe for the stocker and get it inspected)
I don't know why you would throw a code though. My GST had straight pipes on it and never threw a code at all.
1991 GSX 2.3 Stroker
Old 09-05-2007, 08:52 PM
Every once in awhile ill get that P0420 catalyst efficiency below threshold. But have never had the o2 sensor bank 2 code.
When I had my front o2 sensor unplugged, I got that bank 1 code. It's possible that the sensor might just be bad. Although I'd hate to buy one just to turn the CEL off since they really serve no purpose anyway.
Also I've heard through the rumor mill that these cars will pass emissions without a cat anyway. Keep in mind this is just what I've heard and have no idea if its true or not. Correct me if I'm wrong, but if you fail an emissions test you aren't charged for the test. Aren't you only charged if you pass, or if they fix the problem for you?
94 Talon 1.8L-SOLD
Old 09-05-2007, 11:18 PM
Black99GST's Avatar
i pass the sniffer with Flying colors w/o a cat, but i fail the OBDII test which is required ON TOP of the Sniffer and safty here... i just need that code to be fixed because if i clear it, it will say "system not ready" for the OBDII test, and again, i will FAIL... i made bypass simulator, so the stock o2 isnt even in the car, i have a wideband where the stocker was... but the code that is popping up is for the Rear o2 sencor Right? it kinda freaked me out when it was saying shit about bank 1 sencor 2 or something on the reader @ advanced autoparts... any tips from anyone?
Old 09-06-2007, 12:28 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
These cars stock may be able to pass the sniffer without a cat, but look at what you guys got done to them.
I cleared my CEL on the way to the emmissions place... and I have a cat and a rear O2. Had some problems with the rear O2 not working right and kept getting CELs. Actually threw the code again on the way home, like a mile from the place.
I heard putting a Silencer on the muffler helps in the sniffer test. Weird. IDK how true that it.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-06-2007, 01:10 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I dont have a cat, followed the resister mod from tuners for the most part and it took care of my cel completely.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-06-2007, 10:43 PM
Black99GST's Avatar
how did you do it? that is my best option, and i did it...
-1-Megaohm Restrictors (˝ watt 5%)
-4-50 Ohm Wire wound Restrictors (10 Watts, 10%)
-1-1.0uF Metalized –film Capacitor (radical leads 250WVDC max)
but for some reason, i still have the code!
Old 09-07-2007, 10:59 AM
defiancy's Avatar
If you live in Cali, you will not pass the sniffer without a cat.
Old 09-07-2007, 11:29 AM
Holset powered 420a
The way I did it does not allow you to remove the o2 sensor, but it keeps it from throwing a cel for no cat.
I tried to totally eliminate the o2 sensor but I still would get a cel every now and then and the 50ohm resisters got incredibly hot that it was starting to look like a fire hazard. I only used 3 but they would get to around 200F in about 15 minutes. So Heres what I did, I used a 1Mohm resister and 1uf capacitor. Hooked the o2 back up like it was stock, then spliced into the o2 signal/ground wires. And soldered the resistors in between the wires. I used to get a cel every few weeks or so but it has been about 4-5 months since I have seen one for that.
Let me draw a pic so it will be more clear.
http://i189.photobucket.com/albums/z...g?t=1189183087
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-09-2007, 02:08 AM
Black99GST's Avatar
is there a certain flow of electricity thorugh the 1Mohm resister and 1uf capacitor. if so, could i just have them backwords? hmm... i'll have to look into that tomorrow...
changin the conversation back to the problem im having... regardless of where i live (calif/NY/Florida/Mexico) i need the check engine soon light to shut off about not having a cat, perminately. not only does it anoy me, but it is keeping me from passing OBDII emissions. what can i do (*that works*) that will make the computer *THINK* i have a catalytic converter with out having a catalytic converter?
