Ok I know I'm a girl and all but I do know a little about my car. Here's the facts about it. I have a 91 Acura Integra GS with 200,000 miles with the original engine ( I know its a lot but I do baby my car).
Well the engine rheevs up and down from 2000 RPMs to 1000 RPMs dramaticly. I do know it has to do with the air intake. I took it to a mechanic and they ran a diagnostic test on it. They said I have to replace the throttle body...well a new one is 500 dollars and that is a little steep for this college student. So I went to a junk yard in atlanta and got a used one, it was in good shape with a warrante on it from a honda yunk yard. (that yard was hard to find too). Well it still rheevs up, not as bad though...and once the car has been running for a while it stops reeving up. But when you turn it on it rheevhs up really high then drops... then really high then drops...reeerrhh reerhhh reerrhhh...lol. Anyway you guys this is really annoying and my gas mileage is suffering too. I know its something with the air intake cause when I spray throttle body fluid in it, it stops for a second then does the reeeving again. Please help me, or tell me somewhere that can withour riping me off. e-mail me at [email protected], thanks |
There's an obvious vacuum leak. While the motor is surging up and down like that, spray that throttle body cleaner on the air intake and all around. When the surging stops for a little bit where you are spraying, that is where the vacuum leak is at. Check all vacuum lines going into your air intake. sorry if you already knew all of that
FLINT BLACK 1990 CRX SI Appearance Mods: -JDM EF8 CR-X SiR Spoiler -94/95 Integra GS-R rims Performance Mods: -JDM B18C swap -OBD1 conversion -Chipped P28 ECU -Skunk2 Intake Manifold -DC Sports 4-2-1 Header -MSD SCI-L ignition -EXEDY Racing Clutch Interior Mod -'95 Integra GS-R Gauge Cluster Former Motors - RIP: -JDM B16A #1- Blew up due to over-revving -JDM B16A #2 - Hydrolocked Former Cars '89 CRX Si - "The Bumblebee" '94 Integra GS-R![]() '96 Camaro
the mechanic isnt telling the truth he is guessing, a technichian would tell you that you have a vacumm leak. you may need a new throttle body gasket or intake manifold gasket. check all of your vacum lines. a way to tell if you have a vaccum leak is to take brake clean or carb cleaner and spray it where the gasket is. and if it goes away there is your prob. good luck
:smoker2:kaytec4door:smoker2: mods done: AEM cold air intake, ractive racing cat, ractive axel back exhaust, NGK plugs, nuespeed cross-drilled rotors, EBC the green stuff pads, projecter headlights, clear corners, carbon fiber tails, Z3 fenders, adjustable coilovers, Konig flatline rims with dunlop fm901 (17*7), full complete sound system with two 10'' subs, kenwood 600w amp, punch cap, pionner speakers all the way around, full custom interior paint job, reverse indiglo guages, aluminum gauge bezel, d16a6 head swap polished, 4-2-1 ceramic coated header, :finger4: proud member of team kay tec:finger4: |
Thanks you guys, you guys described my problem exactly with the cleaner I was using before. I will definitly replace the vacume hoses.
