Originally Posted by gospel25514
Hey I have a 1992 Protege with 1.8L. The car has a extremely high idle when first started. After about 3 mins it comes back down to regular idle and sounds great. I have noticed that there are some whitish/blue smoke coming from tailpipe when started also. Anyone have any idea of possible problem?
IS THE SMOKE MORE WHITE OR MORE BLUE IN COLOR? IF MORE BLUE, IT IS BURNING OIL, AND WOULD LOOK TO SHECK THE OIL SYSTEM FOR LEAKS, IF MORE WHITE, I BELIEVE IT'SJUST WATER VAPOR, WHICH COULD BE CAUSED BY TOO RICH A MIXTURE OF FUEL. IF YOU ARE USING THE SUPER PREMIUM GAS, TRY SWITCHING TO MID GRADE FOR A BIT, ABOUT THREE WEEKS. IF PROBLEM PERSISTS, YOU MIGHT WANT TO EITHER TAKE IT IN TO A MECHANIC, AND TELL THEM YOU NEED TO ADJUST THE TBI (SOMETIMES CALLED A TWEAK) ALSO, YOU DIDN'T SAY WHETHER ITS CARBEURATED OR TBI, SO YOU MAY NEED TO ADJUST SOME STUFF IF IT'S CARBEURATED TOO. IF IT IS HOLDING THE HIGH IDLE, YOU MIGHT HAVE A STICKY INJECTOR,TOO.
