Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-03-2007, 07:39 PM
macruadhi1995 macruadhi1995 is offline
Please help, Distributor removal, 91 Caprice
I am replacing the pickup coil on a 1991 Caprice. I've got the distro ready to remove, but there isn't enough room to remove it. It seems that my only option is to pull the engine to get it out. Is it really my only option? Please help, this is my only running automobile and I badly need it back on the road.
Old 09-03-2007, 08:19 PM
rhandwor rhandwor is offline
Re: Please help, Distributor removal, 91 Caprice
Make a mark on the base and the distributor. Use white out and mark the rotor and base of distributor. Remove the cap and wires. You should have room to remove it. If you still have a problem give exact size of your motor.
Once it moves upward and comes out of the drive gear you have some room.
Old 09-03-2007, 08:37 PM
It is a 305, I have the distributor positions marked, hold down clamp removed, I've tried to pull the distributor straight up and the firewall is directly over the top of the distro shaft. I've tried pulling it straight up until the gears disengage then pulling to the left, right, and front, but the shaft is just too long. Didn't know if anyone else had done the repair before.
Thanks,
Eric
Old 09-03-2007, 08:44 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Did you take the cap off?
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
I've pulled the distributor a few times on a 305 it is close but they always came right out. You can always pull the motor mounts and lower the engine slightly.
Remember the distributor cap has to be removed.
Old 09-03-2007, 08:47 PM
Um, yes, I did remove the cap, and rotor. But I guess I'll have to try lowering the engine to get it off.
Thanks
Old 09-03-2007, 09:28 PM
CD Smalley CD Smalley is offline
You should be able to tip it forward, towards the front of the car, to get it out. Raise it as far as you can and try tilting it before you do anything drastic.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 09-03-2007, 10:45 PM
463's Avatar
463 463 is offline
i know it's tight due to the 91 - 93 body style, when we replaced the eng,(305cid ) the distributor was replaced on the stand and then installed in the car. i will look in the manual for more infromation for you tuse am. on the pre 91 cars it's a more or less a straight lift out of the eng.
Old 09-04-2007, 01:07 PM
463's Avatar
463 463 is offline
my 91 caprice service manual on page 6d4-5 & 6. Disitributor with separate coil, remove or disconect. 1.neg(-) battery cable 2.plug wires 3.cap (note the rotor pos). 4. disitributor clamp bolt and hold down clamp 5. disitributor -note rotation of rotor as disitributor is pulled up and mark the final position. -Tilt disitributor towards driver's side of vehicle and pull out. On page 6 for a HEI Module it is not necessary to remove the disitributor from the vehicle. Pick-up Coil removal is required. Hope this helps you out. 463
