Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-03-2007, 07:19 PM
needsnewcar needsnewcar is offline
needs a 74 inch serpentine belt
anyone know if theres a nother car, truck with a 4 or 5 rib serpentine belt that is 74" to 74.5" long?
Thanks
Old 09-03-2007, 07:38 PM
denisond3 denisond3 is offline
Re: needs a 74 inch serpentine belt
You should be able to get a serpentine belt in the length you need without knowing the vehicle it fits. The belts have a fairly standard numbering system. The gates belt for my Chevy G20 with 350 v8 has a crossover number below its Gates number: "6PK2567" meaning it is 6 ribs wide, and close to 2567mm long, which is a little over 100". And I think that is why the Gates number is K061010 - being 6 ribs, by 101" long. I would think a 5PK1900 would be a 5 rib belt that was about 74" long.
A good counterman should be able to turn up any serpentine belt on this basis.
Old 09-04-2007, 01:09 AM
Cat Fuzz Cat Fuzz is offline
I'm curious to know why you need this certain length. If you have added or taken away an option on your Saturn, there should be a belt for it.
Old 09-05-2007, 02:05 PM
Alleninpa Alleninpa is offline
gates k040745
http://www.rockauto.com/dbphp/mak,GM...erpentine+Belt
Old 09-13-2007, 07:45 PM
At the time i was planning to remove the a/c (not working) and add a second alternator, using the a/c bracket.
So i went to napa auto parts they didnt have a listing for that size. Ended up making a new bracket out of 310 s.s, witch able me to use the same belt.
Thanks all for your time and Replys
