Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 09-03-2007, 07:03 PM
Drag214 Drag214 is offline
Do it your self; Tips
Hey if you have done some type of maintenance or troubleshooting on your lincoln ls, Share your knowledge.
I am trying to change the transmission floid in my lincoln ls sport. I can't find the fill plug.
Old 09-04-2007, 12:29 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Do it your self; Tips
There is no "fill plug" per se. The fill plug is the same as the drain plug.
Check the maintanence manual though, I believe the service interval is rated at 150k miles. A special fitting is needed to fill the transmission properly. I'm not sure if that plug is available to the general consumer yet.
-Rod
Old 09-05-2007, 10:41 AM
Thanks.
I may just need to chuck up the courage and finally take her to the dealer.
From the sounds of things, I'm going to need a new shift solenoid.
