Old 11-20-2002, 06:59 AM
manthei manthei is offline
Send a message via AIM to manthei
no heat in 2000 blazer
my 2000 blazer has no heat, however engine runs fine just had the fluid checked and my temperature guage is also fine, i heard that it is possible for the thermostat to get stuck in the open position which would cause this wonderingt if anyone had any instight to this situation
thanks
Old 11-20-2002, 03:15 PM
cobra1 cobra1 is offline
when you say the temp guage is fine.....does it come up to normal running temp?
in the mean time, turn on the a/c and turn the temp knob over to warm, or as far to the right as possible. this will give ya heat. ive the used the a/c for heat on my 95 S-10 since it was new, and it gives heat faster than the heater ever will.
Old 11-20-2002, 03:24 PM
thanks for the reply i figured it out all i had to do was flush the heater core
Old 10-29-2003, 05:03 PM
jcon213 jcon213 is offline
Re: no heat in 2000 blazer
How do you flush the heater core?
Old 10-30-2003, 09:30 PM
nuttinbuttrouble nuttinbuttrouble is offline
heater core flush
All you need to do to flush the heater core is to remove both heater hoses and back flush the heater core using a garden hose (not too much pressure though). This is a pretty common problem. I just had to flush mine out yesterday. I would recommend buying a prestone flush and fill kit because the same thing is happening in your radiator. You can get them at the autoparts store. You guys also might want to go back and read a post on January of 2003 from bowtiebandit (heater core clogging). He had a lot of good information on the problem and how to fix it. He goes into a lot of detail that is pretty easy to follow.
Old 11-05-2005, 05:10 AM
unclespudd unclespudd is offline
Re: heater core flush
I'm new here, how do I find the Jan 2003 post from Bowtiebandit?
Thanks
2000 Blazer Exhaust panteli2011 Blazer 1 04-24-2010 09:24 PM
2000 Blazer Back Up Light Wont Turn On? panteli2011 Blazer 3 01-23-2010 07:23 PM
2000 Blazer Rear Wiper sprayer panteli2011 Blazer 1 01-22-2010 09:40 AM
2000 Blazer Heating Problem ripcordres Blazer 15 01-23-2005 07:26 PM
