Go Back   Automotive Forums Car Chat > Ford > Contour
Old 09-03-2007, 11:34 AM
autoa autoa is offline
sputters under load
98 contour Z tech sputters under load. It idles ok and cruises at same speed ok but when power braking or accelerating it sputters or skips bad. Changed plugs air and fuel filter which seemed to cure problem for a day or so. Have run 6 bottles of injector cleaner at fill ups and 3 bottles of water remover with no change. It SEEMS to be not so bad with a full tank of gas and progressively gets worse the lower the fuel level. Code is P0301 cyl 1 misfire. No other codes
Is it a bad injector? Is there a fuel pressure regulator? Fuel pump? Something else? Any help is appreciated. Also locations of possible defective components is very helpful.
Thanks,
Don
Old 09-03-2007, 12:22 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: sputters under load
Sounds like a fuel pump/fuel pump screen is clogged.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 09-03-2007, 01:33 PM
How do you remove the fuel line and the vent line at the pump?
Old 09-04-2007, 07:36 AM
If youre referring to the black and red lines, I think you just pull them out.
"The CEG Nazi"
www.contour.org
Old 09-09-2007, 05:47 PM
Replaced fuel pump............CURED PROBLEM
Old 10-19-2008, 02:22 AM
chippydoo chippydoo is offline
Thanks,
Don
try a new coil pack. it did the trick with my zetec. the coilpack is located to the left side of the engine. its the square box that the wires go to the spark plugs. the same problem can come from a faulty pcm (power control module). its a computer for the whole motor that controlls all the solenoids and sensors telling the motor to buck like all holy hell between 3rd and 4th!! or in your case, the last resort/replacement part for your car. but seriously man, try the coilpack first good luck.
Old 10-20-2008, 06:12 AM
Did you read his last post where he said he fixed the problem by replacing the fuel pump?
"The CEG Nazi"
www.contour.org
