Old 09-03-2007, 07:23 AM
kage67 kage67 is offline
Exclamation key won't turn in ignition.
Hey guys. I'm a single Mom and starting yesterday about 20 minutes after I got out of my van, I went to get back into it to run to the store and the key would not turn. Nothing. The steering wheel is not not locked it just won't turn. I tried the other two keys I have and get the same thing. I cannot get it to my mechanic to fix so I am forced to fix it on my own. Can someone please tell me what to do? I am sure it's the ignition barrel but I've never changed one before.
Old 09-03-2007, 08:22 AM
Exclamation Re: key won't turn in ignition.
Please! Is there someone out there who can help me? Someone who can at least talk me through it? PLEASE!!!!!
Old 09-03-2007, 04:13 PM
Bernard Feltzer Bernard Feltzer is offline
You didn't say what year and model.
You said you wanted someone to tell you what to do, call a locksmith.
Old 09-03-2007, 06:20 PM
enigmaticdragonlad enigmaticdragonlad is offline
If you have keyless entry, the key won't work unless you activate the keyless "unlock". You might also try having a "code key" cut by a local locksmith. The key maybe so worn that it won't active the tumblers in the ignition lock.
Old 09-04-2007, 01:33 PM
Bear Bear is offline
Our cars seem to be prone to the ignition key lock cylinder failing (I have had this issue with my '96 Caravan and '98 neon). I had to replace the lock cylinder and it was a pain to remove, as I had to remove the trim around the steering column and then using a rubber mallet tap on the lock cylinder while trying to turn the key to on. Once the key moves to on, you can look on the under side of the lock cylinder and see a small piece of metal or plastic protruding, push this in with a small screw driver while pulling on the lock cylinder and it will all slide out, then replace the cylinder and re-key
Old 10-27-2008, 04:38 PM
JimRochester JimRochester is offline
Angry Re: key won't turn in ignition.
I just replaced mine on my 99 Caravan with 103,000 miles. It was really seized up. WD40 didn't help but tapping on it with a hammer got it turn enough to take it out. This is one expensive piece. I should have called first. I would have gone to a junk yard and put in a used one. I couldn't find anything online at NAPA or Autozone so I went to the dealer and the part was $156 with them rekeying and using the old keys. The whole van's not worth $156
The replacement was relatively easy with the help I got from this forum. Just trying to line up the screw holes on the trim, was a bitch. That took longer than the actual replacement.
1978 Trans Am Black T-tops 400
1999 Grand Am
1991 Firebird
