Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-03-2007, 01:51 AM
dddaaa dddaaa is offline
removing harmonic balancer 92 cutless
On a '92 olds cutless ciera s 3.3 (V6), I removed the center bolt to the harmonic balancer. But I cant get the harmonic balancer off. How after the center bolt is removed do I get the harmonic balancer off so that I can replace the crank sensor behind it?
Thanks for whatever help!
Old 09-03-2007, 06:01 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: removing harmonic balancer 92 cutless
You'll need a puller for this, and spray some lube into the keyway if you can that'll help.
Hope that helps
1999 Grand Am SS 3.4 OHV
Old 09-04-2007, 06:28 AM
Hope that helps
Can it be pryed off with a crow bar or something? Lube? WD40?
Old 09-06-2007, 09:26 AM
If you pry it off chances are you'll bend the crank pulley and it'll wobble then rip your belt to shreads.
It probly on there pretty good, WD will work fine though.
