Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 09-02-2007, 05:24 PM
azazel_18_2 azazel_18_2 is offline
Fidanza Flywheel Help
I have a 98 honda civic that I swapped out transmissions yesterday because I was tired of the dx trans. I went for a 95 civic ex manual trans. I bought a stage 3 ACT clutch and a Fidanza aluminum flywheel. Now I have problems. The car will idle all day long with no problem. It's when I'm rolling and press the clutch pedal the engine dies. It doesn't matter how fast I am going or not. If you take too long between changing gears the car died. It has plenty of power and there are no CEL's. I also have an underdrive pulley on the crank. Anybody know how I can fix this or am I screwed? I has to mess with the idle adjustment first because it wouldn't even idle so I turned the idle screw on the t-body a 1/4 of a turn and now it idles at about 850 rpm. I am just stumped and have no idea what to do.
Old 09-05-2007, 11:08 PM
alphalanos alphalanos is offline
Re: Fidanza Flywheel Help
Did you use the MT ECU? Or maybe your clutch is just too stiff and is stalling the tranny.
96 EJ6. Future home of boosted B18C1.
Old 09-06-2007, 09:47 PM
I already had a manual trans so I didn't have to change the ECU. When I come to a stop if I just lug it in gear down to 1500 rpm then push in the clutch it will not die. I guess I will just have to change my driving habits. Fidanza tol me the only thing I could do is go back to my OEM crankshaft pulley. I have an underdrive on it.
