Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 09-02-2007, 01:43 PM
quest96 quest96 is offline
heat problem
my 04 crown vict is only putting out cool air through the floor vent and defroster as well. the temperature knob is not making any difference when i turn the temperature all the way to hot. the heater core hoses and radistor hoses are all th same temp. there's no anti-freeze leaks aywhere, the air conditioner is ok and the temp gauge is normal the door opens and closes properly under the dash. where should I start looking now?
Old 09-06-2007, 03:21 AM
KimMG KimMG is offline
AF - Advisor
Re: heat problem
The heater core maybe clogged.
Old 09-06-2007, 12:15 PM
reekor reekor is offline
Re: heat problem
How do you know that the door opens and closes properly under the dash. If you are talking about the door that is under the glovebox, that one is to let outside air into the car. The door that more then likely isn't working is inside of the heaterbox that you can not see. It is controlled by an electric motor that is more then likely the source of your problem. Get ready to remove the dash.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 09-06-2007, 05:30 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: heat problem
If you are patient, you can remove the door actuator through the glove box hole. Tight, but we do it every day.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
