Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 09-02-2007, 11:47 AM
nZero nZero is offline
Horn out
The horn on my '96 S doesn't sound when the switch is hit anymore. The horn sounds if it's directly to the battery. Replacing the relay didn't change anything. Is there another fuse or something I should be looking for? Can the switches blow even though they're on the low-current side of the relay?
-nZero
Old 09-02-2007, 02:18 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Horn out
Could be a bad switch. Check the fuse first though.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 09-03-2007, 07:39 PM
Re: Horn out
Ah okay, so there is a fuse. Where is it located?
-nZero
Old 09-09-2007, 11:59 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Re: Horn out
theres only two places to look in the fuse block under hood and in the car driver side use test light looks can be deceiving make sure u check with key in on position car not on
Old 09-21-2007, 02:04 PM
Jase_Sir Jase_Sir is offline
Re: Horn out
My horn is out too, I have a 1994 Jap import (I live in the UK). I've only just noticed it today.
Did you manage to fix it mate, if so how?
I was a bit confused with Wiseguy01's reply with regards where the fuses can be in the car on the driver side!?!?!
