Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-02-2007, 10:34 AM
soulcrusher soulcrusher is offline
1988 mustang gt no spark
i have repaced the ing.switch and the key switch along with the coil,spark moduglar,pick up,computer,rotor,and the cap. i can pull the coil wire off the cap and put a spark plug in it and get no spark while i turn over the engine but will get 1 spark when i stop rolling over the motor and switch it off
Old 09-02-2007, 10:57 AM
taillight taillight is offline
Re: 1988 mustang gt no spark
I had one where the toothed wheel in the distributor was bad. Put a ac voltmeter on the pick up wires and crank the engine. You should get over 1 volt ac.
Old 08-23-2008, 10:09 AM
it was the pickup in the dist. the one i bought was bad tookit back and got another one now it works fine.just thought i would do an update incase anyone else had the same problem.keep in mind just because they are new parts dont mean they work
