Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 09-02-2007, 12:47 AM
toolfan8102 toolfan8102 is offline
92 STS Suspention Question
I may need to replace the struts on my 92 STS soon, I was told they don't make the electronic adjustable struts anymore. has anyone gone to the aftermarket non-adjustable ones. I plan on doing it myself, but what brands are good? How much can you tell a difference in the ride? Is it worth trying to fix the sensors or electronics, or is it better to just bypass it? Any info is much appriciated
92 STS
Old 09-02-2007, 07:12 AM
DFBonnett DFBonnett is offline
Re: 92 STS Suspention Question
Are your struts bad/soft/leaking or are you just getting the "Service Ride Control" message on the DIC?
Non-electronic struts are available from Strutmasters, Arnott, and Monroe, plus others, I would imagine.
Old 09-02-2007, 10:29 AM
ISmellRubber's Avatar
ISmellRubber ISmellRubber is offline
The best price I was able to find for the conversion is http://www.suspension-alternatives.c...ion-Parts.html . This has all four for about 350! That is a great price for new parts that you need to take care of regularly plus they have a good waranty that they back up too. Most shops will charge you about the same price for doing regular struts and shocks.
Old 09-02-2007, 10:40 AM
I am getting noise in my front end, which leads me to believe it is either struts, or strut mounts, but if I'm going to do one I might as well do the other. The struts do not seem to have a leak or anything, but I am getting the service ride control message.
92 STS
Old 09-02-2007, 01:10 PM
On these cars such a noise, typically a clunk, is often due to worn sway bar bushings. You may want to take a good look at that before you get into the struts.
How many miles on the car?
Old 09-03-2007, 12:18 AM
caddydaddy caddydaddy is offline
The sway bar end links are also known to produce a clunk noise. I replaced them on my '94 Deville and the clunk went away.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 09-03-2007, 12:23 AM
130k, I never thought about that, thanks.
I don't have too much experiance in diagnosing suspention issues. I haven't crawled under it yet, but plan to in the next few days. Is there a way to test it or will it be pretty obvious? I know every car is different but what should I look for?
92 STS
Old 09-03-2007, 12:51 AM
The bushings may be obvious, if you take one off and see it's pretty worn and/or cracked. They are cheap to replace anyways. The sway bar end links can look fine, but make a clunk. With that many miles, I'd replace them and that should solve your clunk noise. They are around $90 for the set, but it's worth it if they get rid of the clunk!
2000 Cadillac STS
Old 09-03-2007, 01:24 AM
Thanks, you guys probably saved me lot's of $$$
92 STS
Old 09-05-2007, 09:50 PM
patterson's Avatar
patterson patterson is offline
I have a question about Cadillac suspension, maybe we can expand this thread a little.
My 95 Eldorado has begun doing a little side-to-side shimmy at crawls speeds. It's kind of a waddle, seems to be originating from the rear end. It disapears once I get over 20mph, not the car, the waddling. lol
I checked the lug nuts, they are all tight. Also, it is independent of applying the brakes.
Any notions on this one? thanks
`95 Black Cadillac Eldorado...Fast and luxurious.
Old 09-06-2007, 02:55 PM
Best to start a new thread when changing subjects. That being said, sounds like a bad tire. Take each rear tire off in turn and feel both sides for bulges or other deformities.
