My sister in law has a venture, not sure of the year, and I don't know the engine, but she says the Change Oil Light is on. She also tells me there is a way to reset the light. She just had the oil changed, but doesn't know how to reset the light. Anyone know how to do this?
Bending wrenches and turning air into the Sound Of Freedom!!! |
Re: Oil Change Light
Basically all Ventures came with the 3.4 engine. Not knowing the year there is two possibilities that may work. The first is to turn the ignition on but do not start the van.Fully depress and release the accelerator pedal 3 times within 5 seconds. If you notice the "Change Oil Soon" light flash that means it is resetting. The second way is to turn the key to "Off". Push the trip reset button and hold it for 4 to 5 seconds. If it has properly reset itself it should read "Oil 100". Either way that info should be in the owner's manual under the heading "Oil Life", if your sister-in-law still has the manual.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
When all else fails, read the instructions.
That first way with the accelerator pedal sounds like what she was trying to explain to me, but she couldn't remember the actual procedure. I have told her what you told me. She will let me know if it works. Thanks for the quick reply.
hope this helps
