Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 09-01-2007, 09:59 PM
darkangel32987 darkangel32987 is offline
97 wrangler cranks but won't start
1997 Wrangler SE 2.5L 4Cyl.
Here's the jist. Started up.. backed up like 5 feet and it dies. It's not starting now. Cranking just fine. It seemed that it just wasn't sparking like the iginitoin coil went out, but i bought one and there are still no sparks... literally put a screw driver in a spark plug connector and held it and did not feel a thing. Where else do I need to go from here?
Old 09-10-2007, 10:02 AM
Invisibleman Invisibleman is offline
Re: 97 wrangler cranks but won't start
Thats a classic "CKP" sensor...known for going out this way in 97-2003 wranglers. It stands for "crankshaft position sensor" It costs about 67 bucks for auto trnny, 122 for manual...don't know why the cost difference. Should not be a hard job to do. Research it a little....I'm gonna bet 90 percent thats your problem unless you have a car alarm screwing things up. Good luck.
Old 09-11-2007, 11:58 AM
tomvid tomvid is offline
That does sound right. However, you should get a check engine light on when that goes bad. It did for my 97 anyway. It is a really easy fix. It has a wire conector and it threads in like a standard bolt.
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
Old 09-11-2007, 07:28 PM
Thanks Invisibleman... The Jeep runs yet again for another day :-)
It probly did pull a check engine light but the battery wasn't connected well and after a few cranks it disconnected so it erased the computer.
Old 10-05-2007, 08:46 PM
jeep mechanic jeep mechanic is offline
my exhaust header pipe came loose and the hot exhaust cut thru the crank position sensor harness. i had to go to autozone theres was $127.00 plus tax
THE EARLY BIRD MAY GET THE WORM...BUT THE 2ND MOUSE ALWAYS GETS THE CHEESE!
