Old 09-01-2007, 09:37 PM
quackmandude quackmandude is offline
tach help
i installed an aftermarket digital tach from deft racing, a 52mm. it looks clean but the reading seems off from the stock tach. ex. whne im at 3k the digital tach says 5k, its weird. i need to get a shift light also but i want the digital one to be right on the money. my friend hooked it up and he said tomm hell mess with it. he connected it to the ecu. can someone tell me what wire or pin to connect it to in the ecu, that would make things hella easier, thanks
'94 3kgt SL
-ebay intake (why not)
-2 1/2 inch straight pipe exaust, custom y downpipe
-Ignition mods
-dual magnaflow exaust
-going TT (wish me luck)
black book
-'95 mustang v6 (modded) /////
-'00 neon (modded/non-turbo) ///
-'04 eclipse GT
-'05 eclipse GT (modded)
-'97 Prelude vtec (modded)
-CRX (modded)
-Mazda Miata mx5 //
Old 09-02-2007, 11:42 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: tach help
search on stealth316.com for how to install safc.. that should help
Jason
Old 09-02-2007, 06:20 PM
Re: tach help
ok new problem, we though we had fixed it, we mess withit and connected to what we thought wa sthe correct wire, it was accurate at idle. but when i get on it, its wayyyyy off, but when i go back to idle, its better again, i dunno wtf. the gauge it self is set to 6cyl on the back on it. is there a connectection on the cpu thatll give me some of those symptoms?
'94 3kgt SL
-Ignition mods
black book
-'04 eclipse GT
-CRX (modded)
-Mazda Miata mx5 //
Old 09-02-2007, 08:10 PM
Hotshot8792 Hotshot8792 is offline
Re: tach help
I don't have instructions to hook up an aftermarket tach, but my guess would be to connect it to the RPM wire going into the ECU, or the pin labeled TACHO at the power transistor unit. ECU pin numbers and info on the PTU can be found on stealth316
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
