Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-01-2007, 05:39 PM
ABigWeaney ABigWeaney is offline
oil pump problem
ok this might be a dumb question but is there a gasket between the oil pump cover (thing im not sure what it is) and the front cover it goes over the gears, and bolts to the oil pick up. but i cant remember if it had one on there when i took it off and there is not one in the gasket set.
i have pictures but dont know how to put them on here.
Old 09-02-2007, 12:25 PM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
Re: oil pump problem
I think there are only two gaskets on the oil pump,but on the other hand I would look in my Haynes manual just to make sure.I cant find mine so you will have to do some looking of your own.
Old 09-02-2007, 06:34 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
If this is what you're talking about then no, there is no gasket. I believe I used some red locktite on the bolts though.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 09-06-2007, 01:33 AM
so there is no gasket between the 2 parts? i looked in the manual i got and it wont tell me a lot of stuff about the oil pump, is there any gaskets or seals in there with the gears?
Old 09-06-2007, 03:50 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Yes there is a gasket.
http://www.extremepsi.com/store/cust...1&veh=2G%20DSM
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 09-07-2007, 08:15 PM
Testiklees
Thats the FRONT CASE and OIL FILTER HOUSING gasket set along with the seals (including the oil SEAL, not gasket, we talked about). What I am talking about in my picture is in the upper right hand corner with those bolts that are in it. That covers the oil pump gears. There is no gasket that goes between it. Yes there is a gasket that goes between the front case and block which is the blue one in the link above.
Tim
1990 Talon AWD
PTE SCM5031
