Go Back   Automotive Forums Car Chat > Dodge > SRT4 > SRT4 Problem Diagnosis
Old 09-01-2007, 02:12 PM
MrCrazy's Avatar
MrCrazy MrCrazy is offline
wheel chatter
i put a stage 2 clutchmaster in my srt and its been been through enough miles to be broken in... but i still have that fucking wheel chatter!iam thinking it just wasnt intalled correctly? anyone got any ideas?
http://www.cardomain.com/ride/2865492
-AEM short ram
-XO2 racing intercooler
-GReddy blow off valve
-Injen downpipe (spits flames!...runs a little rich...lol)
-SAMCO piping
-Mopar stage 2 kit(injectors, ecu, wastgate...)
-KOYO perofrmance radiator
-TIEN lowering springs
-18 inch r2 rims(i dont use these for the track...)
-stage 2 Clutchmaster
-XO2 short shifter
-XO2 oil cooler
-removed 2 resinators
Old 09-01-2007, 09:23 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: wheel chatter
What do you mean chatter? Whilst driving or idle or what?
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 09-02-2007, 01:13 PM
MrCrazy's Avatar
Re: wheel chatter
well at a stop and and barly taking of letting clutch out at 1100 rpm or soo the car front end kinda shakes and feels like the tires are not catching grip....
-AEM short ram
-SAMCO piping
-XO2 short shifter
-XO2 oil cooler
Old 09-02-2007, 05:41 PM
Turbodog97's Avatar
Just a Neon
Re: wheel chatter
You sure it's not a motor mount?
05 Srt4
97 Mx-5
Old 09-04-2007, 03:24 PM
MrCrazy's Avatar
Re: wheel chatter
no cuz it does more and more the motor gets hot! when i first turn on the car and the tranny and motor are cold it runs perfect! but when i start driving for more then lets say 20 minutes it will start the wheel chatter! i tend to hav to kinda over rev to get it moving from stop position... if i over rev to atleast 2000 rpms and let go clutch it wont chatter but 1300 or les it will!
-AEM short ram
-SAMCO piping
-XO2 short shifter
-XO2 oil cooler
Old 09-04-2007, 08:17 PM
wayneo69 wayneo69 is offline
Re: wheel chatter
neons are hard on the motor mounts and lower control arm bushings i replace them daily. hey by the way wheres the nos???????????? check the upper and lower motor mounts make sure they are not torn or ripped
Old 09-04-2007, 08:48 PM
Turbodog97's Avatar
Just a Neon
Re: wheel chatter
You replace your bushings and motor mounts daily? Sounds kind of a far fetched if you ask me...but either way...there is some truth in your statement...srt4's/neons are hard on their mm's and lca bushings.
Please explain more about this clutch/tranny issue. Who did the work? Does it grind or have trouble getting into any gear? Any clutch pedal vibrations? How loud is it...you sure it's not the tb or tb fork?
05 Srt4
97 Mx-5
Old 09-05-2007, 06:43 PM
Re: wheel chatter
its not far fetched when you get about 8 neons in the shop everyday they are a very comon problem srt4 or not it is just bad designing
Old 09-05-2007, 06:44 PM
Re: wheel chatter
did the flywheel get resurfaced or was it just cleaned up
Old 09-07-2007, 11:19 AM
MrCrazy's Avatar
Re: wheel chatter
yes there is pedal vibration when its in every gear! but when its outa gfear its fine... wat could cause that??
it was done bye a tranny shop where i live! been going there for years...
ill check the mm mounts..
-AEM short ram
-SAMCO piping
-XO2 short shifter
-XO2 oil cooler
Old 09-07-2007, 05:36 PM
Turbodog97's Avatar
Just a Neon
Re: wheel chatter
Possible clutch fork
05 Srt4
97 Mx-5
Old 09-08-2007, 05:25 PM
MrCrazy's Avatar
Re: wheel chatter
is any site i could go to see or read about clutch fork??
-AEM short ram
-SAMCO piping
-XO2 short shifter
-XO2 oil cooler
Old 09-09-2007, 01:09 AM
Turbodog97's Avatar
Just a Neon
Re: wheel chatter
I'll pm you the info tomrrow...
05 Srt4
97 Mx-5
Old 09-11-2007, 12:01 AM
Turbodog97's Avatar
Just a Neon
Re: wheel chatter
I'm sorry I ment tob fork...Pm'd info...
05 Srt4
97 Mx-5
