Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 09-01-2007, 01:21 PM
Musky39 Musky39 is offline
!995 Jeep GC, A/C cold, then not cold
1995 Jeep Grand Cherokee Limited, V-8, 5.2 liter
The system is full, with no leaks. Sometimes the A/C blows at 40 degrees and its ice cold, then most times it blows at 60 degrees and its not cold enough. It has a new accumulator, installed 6 months ago. Evaporator fins are clear no bugs or anything blocking it. I do notice that it seems to blow colder in the morning rather than in the afternoon or evening. What else could cause this problem? Any suggestions would help.
Gary
Old 09-11-2007, 10:12 AM
samtheman77 samtheman77 is offline
Re: !995 Jeep GC, A/C cold, then not cold
Did you test the pressure switches, low and high. Try to short out the low pressure switch with a paperclip and see if you get continuous cold air. Other thing to try is to see if the blend doors are working under the dash, perhpas they are stuck in an odd position.
Gary
