Old 11-19-2002, 01:38 PM
93vtecer 93vtecer is offline
engine swamp on a junker
My brothers 84 prelude finally gave up. He blew the head gasket and warped the head. Instead of rebuilding it I was thinking of putting the b18 in it from a gsr or if that wont fit the 1.6 twin cam b16. I've heard the 1.8 will fit nicely into a 89-91 prelude, I was wondering if I can do it to his junker. besides the engine, tranny, ecu, and mounts, can I get it in there without pulling the a/c and power steering, or cutting any cross members. he has the five speed carborated engine
Old 11-19-2002, 02:01 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
I just wanted to tell you right now that it is going to be a lot of work. First of all you are going to have to swap out a new tank with fuel pump. Not to mention that the wiring on that is going to be a bitch. Does anyone know if a company makes motor mounts for that chassis?
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 12-01-2002, 11:35 AM
Dweezil6969 Dweezil6969 is offline
hell go for it. find a shop that will do the mounts if you need that done. as far as the electronics go, get everything you can. grab the ecu, harness, mounts, hell get a whole front clip. take what you need and run.
step 2: post pics
`91 CRX DX Kind of moves
`90 CRX Si
Can also be found on:
XceedSpeed.com, MichiganCivics.com, and Zilvia.net
97 lumina engine acting erratically. aptivaa12 Lumina 5 04-22-2009 09:42 PM
For Sale Looking for engines or trannys?? StephanieO Parts for Sale 0 04-17-2009 09:24 AM
Will an engine from a 99 LX fit a 96? in_the_peg Crown Victoria 1 03-14-2009 09:06 AM
engine swamp questions willysunit5 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 12-04-2006 04:28 PM
engine swamp icebrew405 Camaro Discussions 0 11-01-2003 06:59 AM
