Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-01-2007, 12:52 AM
77CapriceClassic 77CapriceClassic is offline
Heater switch problem
Back in April or so I bought my 77 Caprice. When I bought it, the heater/fan/defrost and all that worked just fine. Then I took apart the dash and put everything back how it was and never touched the heater controls and was careful not to move it too much. Well I put everything back to how it was and went to use the heater and defrost to see if it worked and it didnt. I could feel heat trickling out of there but the fan wasnt blowing. Then a few weeks ago my friend was messing around with it and randomly got the fan to start blowing. Is there something I should look for thats loose maybe? Or how should I go about fixing this? Any help would be greatly appreciated.
1977 Caprice Classic - 350/350 Turbo Trans
Old 09-01-2007, 01:35 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Heater switch problem
The switch probably needs replacing. Not the motor switch, but the heater switch (the slider on top). These have a plastic clip in them that tends to break, and when they do - you lose most everything.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-01-2007, 01:38 AM
Are you talking about the one thats inside the car above the radio? If so are they easy to find?
Old 09-01-2007, 01:40 AM
silicon212's Avatar
Confoundingly Lucid
Yes and yes. It was a very common part - yours will interchange with mine and vice versa. Used on LOTS of GM cars from the 70s into the 90s.
When the plastic clip broke on mine, I put it back together with a locknutted bolt instead. It's a trick to get the three springs inside lined up properly, though.
Old 09-01-2007, 01:46 AM
Alright then, thanks for the help!
