Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 08-31-2007, 09:49 PM
94&92Astro 94&92Astro is offline
Belt Pulley
After hearing a noise and all my dash lights come on --I thought my 00 sohc focus had just shredded a drive belt--Upon inspection the drive belt was indeed shredded but I noticed the pulley was cocked to one side and was probably the root cause of the problem---This is not the tensioner pully but the other one that is just bolted to the engine block... I figure I am not the first since Autozone stocks it for about $16.00--Anyone ever have this problem? Any repair tips.. Looks like the only access is from the bottom?
Old 09-02-2007, 09:44 PM
Re: Belt Pulley
It seems these ford pulleys have a plastic insert which the mounting bolt goes through and the pulley rides on.. The heat created when the old pulley went out damaged it, and when I went to the parts store to get another one, they just gave me that your out of luck look... The search is on and I know I can't be the first...Anyone that can enlighten me I would appreciate it.
Old 10-02-2007, 09:17 PM
truckdude239 truckdude239 is offline
Send a message via AIM to truckdude239
Re: Belt Pulley
2000 ford focus just the other day idler pully come apart 20 buxs fora new on at advance auto
Old 10-08-2007, 09:27 AM
Re: Belt Pulley
Did it come with the plastic or PVC insert in which rides on the inner part of the pulley? I had to create one from scratch- I would rather one made for the job...
