Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-31-2007, 06:58 PM
AutoFan27 AutoFan27 is offline
Question 96 TALON ESI Idleing problem please help
Ok guys i could still use some advice please!!!! I ran the car for awhile and finally the check engine light came on so i had it scanned it said the car is running to rich. So what can cause this? What can i try changing. The car runs great while your going but when you stop the idleing jumps up and down sometimes almost stalling. Again 96 talon 2.0L DOHC non turbo only 85k on it.
THANKS ALOT
Old 08-31-2007, 07:43 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 96 TALON ESI Idleing problem please help
Do you have any mods on the car? Its probably just a sensor or something, maybe an o2 sensor.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-31-2007, 08:42 PM
no mods to the car at all. Thats what i am thinking just a sensor, but wouldn't the computer show a code if a sensor is bad, all that comes up is the oxygen sensor saying the car is running to lean.
Old 09-01-2007, 08:46 AM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
My 94 Eclipse Gs did the same thing.One day I am just driving down the
road and next thing I know the Check Engine light cuts on.The next morning I go to get into my car to go to work and it wont hardly crank,starts flooding and the idle was horrible.It turned out to be my 02 sensor and you could also check your Tps that may have something to do with it as well.Good Luck!
