Old 08-31-2007, 01:05 PM
rnelson rnelson is offline
Stay with original ac delco plugs
Recently put new plugs in my ford 150 & truck missed fire everone told me couldent be plugs i replaced with bouch platium so put new orignal plugs back in & runs perfect so imm getting ready put new plugs in my 98 lasabre & belive me it will be replaced with ac delco plugs also on my plentum when mechanic replaced it with another one he forgot put in the p v c valve u will know its missing it used oil & makes a whistle noise thanks
Old 08-31-2007, 02:11 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: stay with original
on the PCV valve on your LeSabre, don't forget the lower o-ring on that PCV either, or it will still whistle or trip an EGR inefficient code due to the vacuum leak at the MAP sensor mounted in the PCV housing cover.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-31-2007, 04:14 PM
ChemMan ChemMan is offline
Might the gap on the plugs been off and caused the bad performance?
2010 Mazda CX-7 2.5L 12000 miles
2003 Chevy S10 Extreme 4.3L 57000 miles
1995 Buick Lesabre Custom 86000 miles RIP
2002 Pontiac Sunfire SE 130000 miles RIP
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
Old 08-31-2007, 09:42 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
I think it was the plugs themselves. I've sold my fair share of plug over the years and many times I've had customers who came back after buying "aftermarket" branded plugs complaining of driveability issues such as hard starting, poor fuel economy, poor acceleration, etc.) When they bought and installed the OEM plug, especially A C Delco for their GMs the problems subsided. The way I look at it is the manufacturer puts millions of dollars into research for the parts for their engines to make sure they will work the best and are the best choice for the consumer. I only use A C Delco plugs and filters in my GM vehicles and never had an issue with any of them.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 09-01-2007, 01:33 PM
BNaylor's Avatar
BNaylor BNaylor is offline
The use of AC Delco spark plugs versus the aftermarket is a debate that will continue for years to come on this and any other auto forum. IMO which spark plugs you use especially on a Series II 3800 engine is more a matter of personal preference and experience. Many of the aftermarkets like the Denso Iridium, NGK double platinum or Iridium and Autolite double platinum APP606 work fine based on my experiences spanning over 10 years with the SII 3800. Certain Bosch plugs are questionable but the Bosch Fusion which is an Iridium seems to work fine.
Also, Autolite and NGK made the OEM plugs for GM when GM had production problems. For example the AC Delco 41-101 Iridiums are made by NGK. The AC Delco 41-101 is the recommended replacement for the '97 and up SII 3800 engine since the older AC Delco 41-921 double platinums and NGK PTB double platinums are hard to come by. The NGK TR55IX and AC Delco 41-101 are similar. Autolite platinum and copper core plugs have a numbering system easy to remember and easily identifiable heat ranges and the spark plug of choice for modded SII 3800 engines especially the L67 not to mention reasonable cost.
Timeslip 08/12/06
AF Community Guidelines
Old 11-02-2007, 11:00 PM
TGMCallie TGMCallie is offline
I totally agree. Why use Voltswaggon parts in a Cadillac?
1999 Buick LaSabre Custom
2001 Cadillac Sedan Deville
1997 GMC Sonoma Extended Cab Customized PU
Old 11-02-2007, 11:03 PM
Walmart has the Autolite Platinum plugs now for 4.66 for 2 plugs and you get a MFG rebate of $1.00 per plug so that makes it a good buy. Good until Dec. 31, 2007
Old 11-03-2007, 01:38 AM
happydog500 happydog500 is offline
You could also ask, Why use Cadillac parts in a Volkswagen?
Well, they might be better?
Old 11-03-2007, 06:51 AM
BNaylor's Avatar
Thanks for the heads up. BTW - Was that for the single AP or double platinum APP?
Originally Posted by happydog500
You could also ask, Why use Cadillac parts in a Volkswagen? Well, they might be better?
Good sense of humor.
Timeslip 08/12/06
