Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-31-2007, 11:40 AM
player11 player11 is offline
Tranny leak?
Check engine light just came on, so I did a little inspecting and found the drive shaft pretty wet. Not sure of the source...can I assume it's from the tranny? Rodeo has 67K miles, tranny flushed at 48k.
Also, would all tranny problems be covered with the 120k/10 year warranty?
Old 08-31-2007, 01:59 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Tranny leak?
It you are the first owner and it is a 2000-2002 it covers all leaks too.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-31-2007, 02:02 PM
Re: Tranny leak?
Thanks...after further inspection and searching off this site..it is definitely leaking from the accumulator gasket cover...seems to be a common problem. Appointment with dealer next Tuesday. Should I have a fluid and flter change, a flush, or just a top it off?. Leaking fluid seems to be in good shape...pink and no smell..
Old 08-31-2007, 03:12 PM
Ramblin Fever Ramblin Fever is offline
Re: Tranny leak?
Might as well change the fluid again, typically 12-15k miles is an EXCELLENT interval for changing out the tranny fluid with partial fluid swaps.
I do not recommend flushes, but if that's what you're comfortable with, I still wouldn't go more then every 25k between intervals.
Keep the fluid in this tranny CLEAN/FRESH and full, and it'll last a long time.
I do NOT recommend that you go more then 30k between ATF fluid changes with a flush, or longer then 20k between ATF changes with partial drain/refills.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-31-2007, 03:33 PM
Re: Tranny leak?
one more question...what is the third pan down from the front of Rodeo? I also see a small drip building from there. torque converter? What would this indicate?
Old 08-31-2007, 05:13 PM
Re: Tranny leak?
Can you take a pic and post it??
1997 3.2L V6 Rodeo
Old 08-31-2007, 05:16 PM
Re: Tranny leak?
Sorry..can't...but it's a few feet down from the 2 other pans...maybe it's a plate. There is a plug right in the middle of it..would the torque converter be above it?
Looking at other pics from that link..maybe it is the guard for the transfer..would that be a little ways down from the tranny?
Old 08-31-2007, 05:44 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Re: Tranny leak?
there should be three (3) pans down there
from the front
1) oil pan, large
2) AT adapter pan, small; the adapter adapted the old trans to electronic
3) main automatic trans pan, large
the little AT pan should also be dropped when doing the fluid/filter change so you get to change more fluid. they will replace that gasket then also
here's an illustration from the isuzu online parts site www.myisuzuparts.com
the adapter pan is #73, the main pain is #1
is this what you are talking about?
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 08-31-2007, 05:55 PM
Re: Tranny leak?
from the front
1) oil pan, large
//bc
down another couple feet heading towards the rear, there is another plate or cover..it may be protecting whatever is above it..I did notice a small drip foriming there after i cleaned everything up. Where is the torque converter located..is there a plate protecting it..and could it leak?
guard for the transfer??
Old 08-31-2007, 07:49 PM
Re: Tranny leak?
If you could post a pic that would work marvelously.
How far away is this 3rd pan you're referring to from the big transmission pan?
1997 3.2L V6 Rodeo
Old 08-31-2007, 07:52 PM
Re: Tranny leak?
2 feet tops
Old 08-31-2007, 08:17 PM
Re: Tranny leak?
2 feet tops...does that mean towards the back or front of the truck. Gonna have to help me out here, I have a 4x2 Rodeo automatic, you have extra gear under yours that I don't have on mine, if it's a 4x4 anyways. And, I can't remember where the transfer case, etc was at on my '91 Rodeo, been too long.
On my current Rodeo, though, I do have 3 pans - oil pan, small overdrive transmission pan, and main transmission pan, in that order from front of truck to rear.
1997 3.2L V6 Rodeo
Old 08-31-2007, 08:19 PM
Re: Tranny leak?
towards the back... 4X4...I'm guessing it's the guard for the transfer.
Old 09-01-2007, 12:18 AM
trooperbc's Avatar
Re: Tranny leak?
..... Where is the torque converter located..is there a plate protecting it..and could it leak?
the torque converter in in the bell housing.
//bc
