Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 08-31-2007, 10:58 AM
tjr19136 tjr19136 is offline
94 Continental Engine Problem
When I first bought the car it would not go over 40 (MPH) I thought it was the transmission......I change the fluid, filter, I knew it wasnt a gear because when i drop the pan it was not any metal. I use a scan tool and it pass all the transmission test...........
So i was just driving the car and the car cut off on me............ I notice a rubber holes pop. I put the rubber hole back where it came from and the car came back on but the engine began knocking/slapping. Now when i take the engine oil cap off it is kicking out alot of pressure. And when I let the car run sometimes the engine stops knocking/slapping.......................
I want to know do any1 here knows whats going on and what should I do
Old 09-01-2007, 10:26 AM
boltswagen's Avatar
boltswagen boltswagen is offline
Re: 94 Continental Engine Problem
PCV valve?
These are my opinions. I'm not a mechanic.
Old 09-01-2007, 10:24 PM
umm......... I dont know what a PCV valve is..............what is it and where is it located
Old 09-04-2007, 05:58 PM
boltswagen's Avatar
Is this a six cylinder?
The PCV on my six cylinder is on the driver's side rear valve cover with a smallish rubber hose to it.
It's just a guess. Maybe you blew a head gasket, too.
