Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-30-2007, 06:22 PM
mehidi mehidi is offline
ls/vtech type r turbo?
hello, i'm new to this forum, i applogize if i am inturupting anyone's thread, but none has been able to help me. i have a 95 intgra, ls block, je rods, type r pistons, je rings, arp studs, gsr head, skunk2 intake manifold, titanium retainers, type r head internals, skunk2 stage 3 cams, stock injectors and fuel setup. i want to know if i can boost safely and how much can i boost, and if anyone can give me suggestion and option of all motor or boost, which ever is cost efficiant. thank you . not putting the car on the street until the decision is made, so please help, the motor is open now with all the parts hanging around just waiting for someone to help. i looked one forum and someone told me with a ls block and gsr head and type r pistons the compression is 12.4:1 (which i don't belive), others told me 11.5:1 and then i saw 10.6:1, please help
Old 08-31-2007, 04:33 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Re: ls/vtech type r turbo?
well for starters with a stock set of injectors boost is worthless youd run lean alot. so bigger injectors for a start. as for boosting typically lowering the compression is better for boosting and since b series stuff is typically highe compression lowering it to a 10.5 to 1 or so would definetly help. but on stock sleeves you risk it all. however if your looking for homemade turbo i just do 7 psi which is safe for most stock hondas. maybe a local speed center or shop might know more.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 08-31-2007, 05:59 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
stay under 350whp and you're fine...get a good tune
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 09-03-2007, 08:58 AM
can you guys recomend any turbo kits, cost efficiant and good. see i am not a honda person but i am strating to be. thanks.
Old 09-04-2007, 08:33 PM
92CivicFoDo's Avatar
92CivicFoDo 92CivicFoDo is offline
Send a message via AIM to 92CivicFoDo
build your own kit. if you already have JE rods, you might as well rip apart that motor and get some lower compression pistons while youre at it
92 Honda Civic EX 4dr
99 Dodge Ram 2500 Cummins Turbo Diesel
Old 09-06-2007, 11:27 PM
well the man asked for kits at least shoot out the names. rev hard makes a bit. greddy makes a good kit. you can check out homemadeturbo.com it will give you some insite. as well as cheap ebay crap. just had to rep the shit i didnt cheap out on. those are the man kits. build as reccomended build it. that way you get exactly what you want. and you can basicly choose how it works.
06 cbr 600 f4i
91 civic hatchback.
Old 09-07-2007, 01:29 PM
Smile Re: ls/vtech type r turbo?
thanks guys, it was alot of help, i have got je pistons and rings and pins with eagle rods, i figure i can do atleast 15psi. well let me know what you guys think, 255 walbro fuel pump, 550 rc injectors, je pistons, eagle rods, gsr head with type r valve train and gsr cams, arp studs, 3" down pipe and exhaust, 38mm wasegate,t3/t4 turbo, 2.5" piping with front mouth intercooler. my local tune shop said between 420-460 whp. scheduled me fro tune next week, can't wait
