Old 08-30-2007, 04:37 PM
dizzydog dizzydog is offline
Unhappy Headlights
I have a 1995 escort lx. The headlights went out. I cannot find where the headlight fuse is (not in box or under hood). Someone else said it might be the relay switch since there is no fuse can't find that either. Please help. I don't have the manual for the car (was bought used). Thanx
Old 08-30-2007, 07:14 PM
Selectron Selectron is offline
Re: Headlights
Hi dizzydog, and welcome to the forum. Here are some diagrams. The first is the wiring diagram - my Ford service manual has a single wiring diagram to cover all the '95 models.
The fuse should be the 'Head' fuse, rated at 30A and located in the engine bay fusebox. The headlamp relay should be located inside the vehicle, near to the interior fuse panel. Let me know if you need any help with the electrical fault-finding.
Wiring diagram
Fuse designations
Fusebox layout
Headlamp relay location
Old 08-30-2007, 09:51 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: Headlights
Have you checked if any other lights are out? To the tail lights come on at all? Do high beams work? Brake lights?
If both headlights went out at the same time then a fuse/relay or the switch is the culprit.
Old 08-30-2007, 09:56 PM
Re: Headlights
Thanx a million Selectron. I'll have to check it out tomorrow. It's dark so I can't drive to get the replacement. vbmenu_register("postmenu_4924212", true);
Old 08-31-2007, 01:35 PM
Re: Headlights
It was the fuse.
Thank You Selectron
