Old 08-30-2007, 01:49 PM
rodfoster rodfoster is offline
low coolant light coming on
i recently changed the coolant in my 96 grand am and now the low coolant light will not go away! i checked the level afterwards and it is fine. has anyone else run into this? hard to imagine that the sensor became faulty exactly when i changed the coolant. any help would be appreciated. thanks
Old 08-30-2007, 04:41 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: low coolant light coming on
Remove the sensor and clean it. Once you reinstall it the light should work properly. These become corroded and will send a false light. Common issue.
Old 09-04-2007, 10:16 AM
thanks for the reply-i took it out and cleaned it-no deposits on it . plugged it back in-light still on! took it back out and stuck it in a glass of water- light went out! took reservoir off, tilted it to get air out of it-no change. light is still on! what the heck else can i try?
Old 09-04-2007, 04:40 PM
crazy Jim's Avatar
crazy Jim crazy Jim is offline
maybe there is something wrong in the plug/wiring
master airframe mech/shadetree auto mech/30+ years experience
current vehicles:
'02 Impala LS 3.8L
'02 Trans Am WS6 LS1 6spd
'99 Grand Am SE 3.4L
'71 Cutlass SX 455/TH400
'04 YZ450F
'07 Kona Garbonzo (dowwnhill mountain bike)
Old 09-04-2007, 05:26 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Also when you fill the res. make sure thiers not air bubbles stuck to the sensor.
1999 Grand Am SS 3.4 OHV
Old 09-07-2007, 10:03 AM
update: light went out! last weekend i screwed with it, unplugged it, tilted reservoir to get air bubbles out, etc. a couple of days later, it went out on it's own! one of the things i check that i thought wasn't too bad an idea, i dipped the sensor in a glass of water-and the light went out, so i knew from there on that the sensor was ok.
Old 09-08-2007, 03:03 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
I use to own a 99 grand am gt, trust me i had every problem with that car you could ever imagine. The coolant light is just a shitty censor design. Where pontiac placed the censor was a bad idea. When your coolant gets hot, especially on warm days, its going to create an air pocket in your reservior, which eventually messes with your censor and tells you your coolant is low. Im really not sure what to do to fix this, never looked into it.....
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 09-10-2007, 11:38 PM
Cleaning or replacing it can also help
