Old 08-30-2007, 08:46 AM
arnea arnea is offline
1992 buick lesabre code 41
Can you have a missing magnet for the cam sensor and still have the service engine light go on and off???? The vehicle has 192,000 miles on it... Thanks Arne
Old 08-30-2007, 11:04 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: 1992 buick lesabre code 41
That is very possible. No magnet would mean no signal to the pcm through the cam circuit and hence the SES light. Before long, it will stay on without cycling until you fix the problem.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 08-30-2007, 03:23 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Wink Re: 1992 buick lesabre code 41
BTW, remember, code 41 can also be the crank sensor (CKPS) Has the timing set ever been replaced?
Old 09-04-2007, 07:57 AM
The timing set has not been changed. I am planning on doing it along with the crank and cam sensors... Anything else need changing while I ahve the engine apart.????Thanks Arne
Old 09-05-2007, 10:10 PM
spinne1 spinne1 is offline
The water pump.
