Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-29-2007, 10:55 PM
Endarias Endarias is offline
Vehicle Speed Sensor
Hi all. 1992 Olds 88. 3.8 ltr. Starts off in 2nd gear and the cruise works sporadically. I think it might be the V.S.S. Has anyone heard of this and if so where is the V.S.S on this particular model. Thank You
Old 08-30-2007, 02:24 PM
maxwedge maxwedge is offline
A990 racer
Re: Vehicle Speed Sensor
Does the speedo work, if so it is not the VSS.
Old 08-30-2007, 07:30 PM
Yes, The speedo works. So im guessing that my speedo is not cable driven?
Old 08-30-2007, 08:15 PM
A990 racer
Correct, the pcm drives it based on VSS input so that is not the problem, the trans should be scanned with a full function trans scanner for solenoid functions and trans codes.
Old 08-30-2007, 09:12 PM
Thank you for the help. Where could i get it scanned and how much do you think it would be. also, i have an OBD 2 scanner. could i plug it up?
Old 08-31-2007, 03:00 PM
A990 racer
A regular scanner will not pick up trans functions, a highline scanner, professional model, or a trans shop would have this capability.
