Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-29-2007, 11:43 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Crazy Rad. Fan
Ok guys I have been trying to figure this one out for a long time. I only have 1 radiator fan, the ac fan is out. Now the fan only seems to cut on when it wants to, most of the time when the car gets to operating temps it will cut on. Well today it decided that it didn't want to cut on so the car started to overheat, I cut the ac on and the fan cut on, when I cut the ac off the fan went off. I cut the car off and the coolant was boiling. Let it cool down some and cranked it back up. This time when the car got warm the fan cut on but after a few minutes it turned off and started overheating again. Drove it around the block and it wanted to run hot when ever I was idleing. Got home and the fan cut back on and worked fine.
I have no idea what could cause this, maybe a bad coolant temp sensor?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-30-2007, 12:49 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: Crazy Rad. Fan
Good Lord, are we the only ones plagued with this running hot mess? What's the temp your showing on the logger? Do you have the fans wired together on the relays? Thats how I have, and when the ac is turned on, they both come on. When the coolant temp reaches 205 they both cut on.
I recently made some shrouding out of sheet metal that I got from Lowes. It seemed to help a good bit. However when i took it on the highway at 100+ outside temps, my max coolant temp got to 115 as opposed to 120+ without the shrouding. This is even with the thermostat taken out.
I've done everything possible besides a new Koyo or Fluidyne. This is my next step. If that doesn't work the condenser is getting pulled.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
