Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 08-29-2007, 11:29 PM
BlueAcrylic BlueAcrylic is offline
Squeak!!!!
1994 Mustang GT 5.0 Conv.
Ok... Guys I can not stand it any longer... I have a squeak.... There I said it...
I have a squeak that has been driving me absolutely insane…
It is coming from both rear sides … brakes I thought
Here is want I have done so far… the metal shroud was touching a little I bent that out, but still squeaked… I changed the brakes pad and had rotors turned, but still squeaked… then someone said I should change the wheel bearings, I said ok … I had NO idea how to do this but yea... I decided to do it on my own… 15hrs later Walla!! Finished… STILL SQEAKS…
This is a sqeak that you hear everytime the wheel rotates...
I need help guys..
Could it be that since I bought the cheap brake pad the Mustang gods is cussing me every single time my wheels rotate??? I think maybe… Before I buy the $60.00 pads I need to know what yall think, so I don’t light my car on fire…
Thanks, Michael
Old 08-30-2007, 10:45 AM
taillight taillight is offline
Re: Squeak!!!!
It could be a cracked rim. try rotating the tires.
Old 08-30-2007, 09:35 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Re: Squeak!!!!
I need help guys..
Thanks, Michael
Put the rear end up on two jack stands (meaning get the wheels about a 1inch off the ground with two jack stands directly under the rear end.
Put your car in gear and see if it squeeks. If it does not, then you might have a bad bearing out back, or...your drive shaft maybe rubbing on your mufflers.
My ride at my site Silverstangs.
Old 08-31-2007, 12:31 AM
squeaky3 squeaky3 is offline
Re: Squeak!!!!
my best advice is if u have acess to a lift then put it up in the air so u can get under it and then u can c where the squeak is coming from
if u cant use a lift just put the back end up enough so u can get under it and put some jack stands under it
BUT MEMBER IF U JACK IT UP TO PUT SOMETHING IN FRONT OF THE FRONT WHEELS SO IT DOESNT ROLL AWAY
i almost had that happen to me and i saw it happen to someone else...it sucks dont do it
ok well that was my .02
bye
Old 08-31-2007, 05:43 AM
Re: Squeak!!!!
Ok i noticed a hair line crack in the drivers side rear wheel.... and it doesnt make any noise when its up in the air... ... dangit wheel cost more than pads... why couldnt it be the dang pads...
How bout if i use my friends rears wheels off his 00' would that work as for a test??
Old 08-31-2007, 11:33 AM
Re: Squeak!!!!
if both the style, wheel and tires are the same size it should work
Old 09-02-2007, 12:37 AM
Re: Squeak!!!!
And it's holding AIR?
Old 09-04-2007, 04:26 AM
Re: Squeak!!!!
… ok I changed to my friends wheels and the squeak was still there… then I took a chance and bought some $61 Hawk brake pads … Walla.. NO MORE SQUEAK!!! Omg …. Thanks guys for kind of helping though my ordeal… it was omfg crazy for me to hear that squeak over and over and over…. (well I guess yall get the point..)
Thanks again,
Michael
