Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-29-2007, 05:23 PM
haroldcalvert haroldcalvert is offline
Automatic trans not shifting
I have a 94 Rodeo, which dirves fine if u are willing to do the shifting manually. The trans cooling line was leaking and i replaced both otf them just before the problem started. Any ideas??
Old 08-29-2007, 05:39 PM
Ramblin Fever Ramblin Fever is offline
Re: Automatic trans not shifting
Did you recheck your tranny fill level??
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 08-29-2007, 06:11 PM
Yes, changed the trans oil cooler lines and replaced lost fluid.
Old 08-29-2007, 08:24 PM
FL 3.2L FL 3.2L is offline
Did you check the level with the engine running and the trans in neutral?
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 08-29-2007, 10:07 PM
trooperbc's Avatar
trooperbc trooperbc is offline
if you are saying your automatic transmission is in 'limp mode' and shifts fine manually, but if you start off in D drive it starts off in 4th gear...
then the cause is electronics. which can be internal trans electronics (solenoids, e.g.), or it can be external to the trans computer, but most causes is the charging system and usually the alternator but can be battery, connectors, wires, grounds...you get the picture.
any other symptoms besides being in limp mode?
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 08-29-2007, 10:09 PM
trooperbc's Avatar
and, how much fluid was lost?
//bc
