Old 08-29-2007, 03:35 PM
sallen98 sallen98 is offline
Smile Blazer 4 Wheel Drive Shift Problems
I currently have a 1996 Blazer that blows fuses when shifting into 4 wheel drive, I can change the fuse and everything work fine for a while. any ideas? TCCM Module? Transfer case shift motor
Old 08-30-2007, 10:02 AM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: Blazer 4 Wheel Drive Shift Problems
You have a short somewhere in the system thats causing your fuse to pop all the time. It could be either, especailly if its intermittent like you mentioned. Is there any constant routine it pops the fuse? Like only if you switch to 4hi from 2hi or 4lo to 4hi etc, etc?
Old 09-01-2007, 05:13 PM
EFGoodwrench EFGoodwrench is offline
Send a message via AIM to EFGoodwrench Send a message via Skype™ to EFGoodwrench
As your encoder begins to age it puts more of a amperage draw on the encoder circuit the wiring was not built to handle the load so it pops the fuse. You can swap your encoder or I think there is a TSB out for the wiring of the circuit.
DO NOT USE A BIGGER FUSE!!!
