Rough Idle
I have a 2000 pontiac grand am 2.4 auto and the problem is in park and neutral idle is fine soon as i put in drive yopu can see steering wheel shake and feel it in your hands idles at 500 -600 rpms if i raise it with gas pedal to 800 rpms its fine looked on throttle body and idle screw is tamper proof
Re: Rough Idle
Idle is controled by the IAC - PCM no mechanical adjustments can be made.
Either of the two could be your problem, but I'd say its your IAC or its circuit/wires. When you replaced the IAC did you calibrate it ? Was the port it sets in clean through to the intake ? I bet that's where the problem resides.
1999 Grand Am SS 3.4 OHV
Re: Rough Idle
Only Parts Replaced Were Coils Boots Plugs Coil Housing Fuel Pump Filters Gas Cap And Fuel Injection Cleaninghave Done Nothing With Iac
Re: Rough Idle
Sorry bout that I thought in your preveous thread you mentioned changing the IAC.
I'd check in to the IAC though ![]() Idle Air Control(IAC) Testing Replacing Hope that helps
Re: Rough Idle
Yes Im Gonna Try Cleaning It Fiorst Thanks
