Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-29-2007, 03:37 AM
deesandvees's Avatar
deesandvees deesandvees is offline
200r4 to 700r4 swap
It's out with the 200r4 that came in my '87 Caprice and in with a 700r4. I went to the junkyard and found a couple Caprice wagons (an '85 and an '86). I got the driveline and the crossmember. Anything else I will need for this swap? Thanks.
Old 09-04-2007, 11:34 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 200r4 to 700r4 swap
Make sure that both cars have the same type of rear axle. Wagons generally had all 8.5s, where sedans had 7.5s unless 9C1 or -some- Broughams, then 8.5s.
The reason? An 8.5" axle puts the yoke about an inch closer to the transmission, requiring a 1" shorter driveshaft than the 7.5", all else being equal.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
