Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-28-2007, 10:08 PM
Andykid456 Andykid456 is offline
Boost Test
Today i just did a boost test and i filled it up arround 10 psi or so and i was hearing a leak arround where the throrttle area i sprayed soapy water and it was bubbleing there. and looks like where a vacume hose is supposed to be hooked up to the the fuel injection in the back air was being blown out of during the test. along with the hks blow off valve there was a little leak coming from the bolt in the back of the hsk what i really dont know what that bolt is for it looks like an ajustment. the idle was going up and down
Old 08-29-2007, 05:29 PM
steviek's Avatar
steviek steviek is offline
Re: Boost Test
and so your question is?
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 08-29-2007, 10:58 PM
Re: Boost Test
when you do a booost test is air suppose to coe out the throttle and the biss screw ti was bubeling all over there and the throttle where the sprring is is that a boost leak or not thanks
Old 08-30-2007, 11:15 AM
steviek's Avatar
Re: Boost Test
no the air is not supposed to come out of the BISS. It is a common place for boost leaks. If I was you I would set the BISS to the level you want to and then fill in the area with some silicone to seal it off. Its nothing permanent but it will keep the air in.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 08-31-2007, 09:34 AM
Re: Boost Test
And another thing its leakink pretty bad out of the throttle in the back where the cable is hooked up
Old 09-04-2007, 10:41 PM
mydelsol mydelsol is offline
Re: Boost Test
thats another common leak. the seals on the throttle shaft leak air out. its not a difficult fix. just buy new seals and follow the vfaq. here is the link if you have a 91-94 http://www.plymouthlaser.com/tbor.htm
here is the link if you have a 90 http://www.dsmtuners.com/forums/show...ttle+body+seal
look at both vfaqs
1993 del sol s
1990 Eagle Talon Tsi Awd
