Old 08-28-2007, 12:53 PM
DSM Monster DSM Monster is offline
what gauges are you running?
so originally i was gonna do boost egt and my wideband af in the center console but i think im actually gonna put my wideband in the grove box. so i was wondering what all gauges people r running?
and while were on the subject: our center guages 52mm or 60mm?
Old 08-28-2007, 02:18 PM
new2mitsu new2mitsu is offline
Re: what gauges are you running?
i believe they are 60mm
Old 08-28-2007, 02:24 PM
Igovert500's Avatar
blue + red light magnet
i have boost currently. Wideband o2 is going in soon, and I expect oil pressure at some point, but surprisingly I think I have the only vr4 in existence with a functioning stock oil pressure gauge. I think I can live without egt personally.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 08-28-2007, 04:00 PM
so what r the plus of a wideband o2? just make tuning easier like the A/F?
Old 08-28-2007, 05:02 PM
Hotshot8792 Hotshot8792 is offline
yes, narrowband O2s cycle for an effecient tune when cruising, however, it does nothing for WOT. Widebands measure and display the amount of air to fuel ratio.
52 mm gauges will fit in the center like the factory gauges. I have mine behind the plexi glass. 60 mm gauges will fit in the actual openings if you like the look of them being right there.
I have aftermarket boost, oil pressure, and water temp gauges in the factory center location. I have a narrowband a/f gauge and an egt gauge, but i'm not planning on putting them back in the car right now as I feel they don't really benefit you. EGTs just help identify when the combustion chamber is getting too hot to the point it could possibly cause knock, but we have dataloggers to monitor knock.
I also have an LM-1 wideband, but its not a gauge, its just a separate unit for when I decide I want to go tuning. I feel like I don't have to know my wideband A/F ratio all the time because
1. I have an e-manage so its not like i can change my tune on the fly
2. I'm using the factory MAS which compensates for temperature changes and pressure changes, allowing the tune to change as needed.
3. One less O2 sensor to worry about all the time.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 08-28-2007, 05:15 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
If you get the AEM UEGO or or a similar gauge there is no point in not mounting it. With the combo of EGT and the wideband you can constantly visually monitor the car and how its doing. I once watched my EGTs skyrocket and WB go lean and immediately got out of the throttle.
Old 08-29-2007, 11:49 PM
you would happen to have any picture of what the 60mm look like do you? i just wanna see how far they stick out past the factorys. thanks for all the input on the matter guys
Old 08-30-2007, 06:56 AM
check this thread
http://www.3si.org/forum/showthread.php?t=261258
i can't really see the pics because most of them are blocked here at work, but you should be able to identify which ones are 52mm and which ones are 60 mm
Old 08-31-2007, 02:08 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
i was running boost and af
