Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 08-28-2007, 12:25 PM
tallcanadian tallcanadian is offline
1989 jimmy 4x4 ball joints
i've never replaced ball joints in a jimmy before. could i get some advice what to do? i have what seems to be wandering steering. i'm told that my ball joints are somewhat tight. i do have one bad upper ball joint so i want to replace both upper and lower. any advice would be appreciated.
Old 08-28-2007, 08:43 PM
loca247 loca247 is offline
Re: 1989 jimmy 4x4 ball joints
I had the ball joints on my 2000 Jimmy replaced in May 2007. The right upper and lower were bad. The mechanic said that all four needed to be replaced so they would wear evenly and once he's in there he might as well do it all at once. They were the original ball joints on the Jimmy (115,000 miles).
Old 08-28-2007, 08:50 PM
my jimmy has 123,000 kms. (approx 77,000 miles) the ball joints are original as well.
Old 09-28-2007, 09:08 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
The top ball joints are riveted to the control arm, so you will need to either drill the heads out, grind them off, or use a air-powered chisel. Grinding does the least damage to the arm since you can see how far to go then stop and punch the middle out with a centerpunch. A Haynes or Chilton's repair manual helps lay out the steps. If not, AutoZone.com has the nearly identical repair guides online, pics and everything. Unsure how the bottom ones are held in. Here is the AutoZone link:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-28-2007, 09:14 AM
jdmccright's Avatar
The RustBuster
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
