Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 08-28-2007, 03:09 AM
locoluis30 locoluis30 is offline
Speedometer stop working 1994yj wrangler
All of a sudden the mileage indicator stop working but the speedometer gauge is funcional. Anyone knows if I should change the whole tach or perhaps a speed sensor? Thanks!
Old 08-28-2007, 08:57 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
Re: Speedometer stop working 1994yj wrangler
you could have a bad sensor, but I had a similar problem with my 93yj when I bought it, and my problem ended up being a bad spot in the printed circit behind the guages.
the bad spot was causing the spedo to not get power. I was able to fix it by just using a short piece of wire and jumping from the tach power terminal to the spedo power terminal.
if you pull the guage cluster out, you will see the printed circit on the back side, just trace all of the "wires" in it to see if any of them have bad spots.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
