Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 11-18-2002, 06:37 AM
Kolorado Ken Kolorado Ken is offline
Strange Electrical Problem
I just happened...
doors and windows don't work & stuck in locked position, but trunk is unlocked - careful could get locked in!!!
car starts and engine runs fine
lights and blinkers are OK
OBC dead, radio dead, elec. seats dead, associated fuses OK
cycled power on the battery, no effect
visually checked all fuses, look ok
removed, cleaned and replaced relays - no effect
visually checked CCM module, looks ok (not elec. test)
Anybody have any ideas?
Ken 92,735iL
Old 11-19-2002, 07:56 AM
Bear Bear is offline
Have you checked the fuses in the Rear Power Distribution Box under (of course ) your left rear passenger seat. Specifically numbers 31,33, 40,42,43, and 44?
Old 11-20-2002, 12:42 AM
Thanks for the reply... I have not got under the back seat yet. I have to crawl over the front seats to get there since only the front passenger door opens. I'll try that and let you know.
Ken 92,735iL
Old 11-21-2002, 10:00 AM
josh0855 josh0855 is offline
Send a message via AIM to josh0855
BUMP I want to know if that takes care of it.:silly2:
Old 11-24-2002, 12:25 PM
I may have found the problem - the "fusible link B". There were so many elements that went out simultaneously.
I had checked and cleaned all the fuses - OK. I removed the relay module and general module, disassembpled and inspected - look OK. Put everything back together and applied power - still out. While working around the rear seat element, I check the voltage going to the group of fuses coming off the fusable link (ele-28 of Bentley repair manual). While moving around this area the fault cleared itself.
I plan on replacing the fusible link.
Ken 92,735iL
Old 04-01-2003, 09:21 PM
This is an old post, but I did not update the final outcome.
The problem just started by the radio losing power, reconnecting and requiring the security code. It gradually increased to where a lot of electronics started to fail.
It was the connection to the battery! The 735iL has two connections, one for starter motor and one to run the majority of the electronics. The electronics battery connection had come loose making an intermittent connection - dropping the voltage to the electronics where some worked and others did not work. Properly securing the battery and terminals solved the problem.
A cheap fix, but an SOB to find.
Ken 92,735iL
Electrical Problems...... GaryCifers Corsica 6 01-13-2010 04:08 AM
Strange electrical problems... xmichelle Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 7 02-14-2006 12:26 PM
Strange electrical problems garywcox Grand Prix 5 07-27-2004 05:52 PM
Strange Electrical Problems! Suzuki4me Esteem 1 07-16-2004 06:18 PM
Multiple strange electrical problems shamus3600 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 11-03-2003 08:47 PM
